Validating 3D source data
Command |
Workspace: Path |
Validate 3D Data |
Architect: AEC > Terrain Landmark: Landmark > Create Site Model |
Use the Validate 3D Data command before you create the site model, to check the 3D source data for problems. Even if a site model already exists, the source data can be checked. If problems occur due to erroneous site model source data, alerts are automatically displayed. A site model with problems can still be created; however, results may not be as expected.
The following problems can generate an alert:
Duplicate 3D data points or polygons
3D data points that are coincident or vertically placed
Missing source data
To validate 3D source data:
Select the source data (3D loci, 3D polygons, or stake objects) to be checked.
Select the command.
If the source data are valid, a dialog box states that no problems were found. Proceed with creating the site model as described in Creating the site model.
If there are errors in the source data, the Problems with Site Model Source Data dialog box opens.
Problems encountered are listed, and some conditions have an associated button for correcting each one by modifying or deleting the erroneous data.
When problem correction is complete, click Close.
Select Validate 3D Data again to ensure that the problems have been corrected.
